Upgrading an 88 FLHTP Drivetrain
Did this on my 87 Heritage a couple years back. 113 with 6 speed and complete new primary/clutch starter. Mostly e-bay for everything. BDL clutch, 05 Primary. Had a couple of clearance issues, but the touring models have more clearance. Runs like a new bike now. Also sold all my take offs for about a third of what I spent on the upgrade. Total out of pocket was around $3500.
Like the 6 speed but now understand when folks say its only useful above 70. I got a lot of pinging rolling on from 3000 RPM's in 5th and 6th. Tried octane boost, tried VOES to no avail. didn't feel like swapping ignition. Reduced comp sprocket to a 23 and ping problem went away. Dropped from low 80's to high 70's at 3000 RPM, but figure it is fast enough and more fun to drive.
If you want to go cheap, get a 5 speed take off (Splined shaft) and run a 34/65 pulley combo. If you are replacing the primary you could also muck about with those ratios. Won't be as quick off the line, but will get you a poor man's 6th gear on the road.
Good luck. Nothing like doing it yourself.
Oh yeah. If you change the starter recommend all *****. The e-bay ultima only held up for about 5K miles.
So, to your bike - you could probably make all that work if your '88 frame and the '93-later frames are the same, and they probably are, or so close that it wouldn't matter. The engine and tranny mounts would have to be the same across those years, I would think. The trick will be to find a 93-later oil pan and 5-speed tranny case at a reasonable price. I've seen lots of trannys in the aftermarket, but they tend to be pretty expensive, and if you're going to a big powerful engine, you'll want a good tranny like a Baker or something, and a good clutch like a Rivera, etc. Those aren't cheap!
The pan is actually TWO pans in one - the front part for the engine oil, and the rear part for the tranny fluid. A new 5-speed tranny would also have the splined shaft for a new style wet clutch. You could also find or fabricate a battery box as well.
A bit at a time is probably appropriate... All this is going to require some "nontrivial cash outlay"!
On Edit: A little more info... my 1995 Police Parts catalog lists -94 suffixes for the inner primary housing and primary cover - so the primary may have changed in '94.
The inner primary housing is shown as P/N 60432-94 - this is a wrinkle black part for the Police bikes - so that may be the only difference from the older inner primary housings that came in a natural finish, or there may be other changes made that year as well.
The primary cover is shown as P/N 60665-94 - and it's chrome. Don't know if the older primary covers were chrome or not... that may be the only difference made in '94, and that difference might only have been for the Police models, or it may have been for all of the touring bikes...
I don't know if the frame changed between '88 and '93. I know the touring frame changed in '97 - it got wider in the middle and rear - not much, but enough to hold a bigger battery, and the rear end got about 1/4" wider. That's why the MoCo has so many accessories that state they fit "97 and later" bikes. I found that out fitting a '97-and-later detachable Tour Pak rack to Bertha. Made it work by simply shimming the mounting bolts out about 3/32" on each side so the rack lined up with the fittings on the mounting bolts.
This is only on the fringe of things, but the swingarms right through to 2007 are interchangeable, the only change to them being a larger diameter axle in 2002 on. So further to NorthGeorgiaHawg's observations, any frame changes from 94 must be comparatively minor, as far as the driveline is concerned.
Sounds like your trans is built enough to handle the extra power. if you could get by with a main shaft swap and perhaps a beefed clutch, that would probably be the easiest way to go.
One last thing:the 113" had an intake leak out of the box. Never could get it to show up with carb cleaner/WD40, and tried all sorts of carb adjustments. Finally replaced the gaskets and it's been fine ever since. That was the only real problem I have had with it. 113 is a good choice. Runs like a raped ape and get's low 40's highway low 30's around town.
The 1990 mainshaft is the only splined mainshaft that can be used with your current gearset. The mainshaft changed in `91 to a larger diameter, so all the gears also changed.
Rather than change just the shaft and use your old gears, you would probably be better off to just find a later model take off gearset.
Ideally an `98 or `99 gearset with trapdoor, because these gearsets have the improved (larger) bearings in the trapdoor.
