rocker cover
rocker cover
I have a stripped rocker cover bolt, rear cylinder, front bolt. The others manage to work themselves loose too and leaks oil all over. Does the engine have to come out to get the rocker covers off? I would like to either get a new bottom rocker cover or heli-coil the stripped thread in there, but it looks to me the frame is in the way to get rocker cover off. 97 FXDWG.
Joe
Joe
Yeah, it is a VERY tight squeeze on the rear. When I did mine I found that I could not get the center section on if I had the bottom section already bolted down because the bolt heads caused interference. So I had to put the bottom and center sections in place then shift the center section around so that I could access the bolts on the bottom section. This made it nearly impossible to use a torque wrench on the bottom section bolts. But I did manage to get it all back together with no leaks... so far.
By a stripped out thread do you mean that the bolt won't hold in the thread? If so you're going to need to pull the head and install a Heli-Coil insert. Or replace the head.
If it's only cross threaded :
Pull the tank, and remove the rear rocker boxes.
Check the three pieces on a plate of glass or other known FLAT surface for warpage. It's not going to do any good to put a warped section back on (ya gotta trust me on this one).
Take a 'thread cleaning' tap and see if you can 'clean up' the threads in the buggered up hole. Test using one of the rocker box bolts. If this can't be done, you'll probably need to remove the head and get a heli-coil insert installed. Or upgrade to some new heads. Offhand, I can't recall if there would be enough room to drill the head with it still on the engine in the frame.
I have zero experience with the Loctite thread maker liquids, but perhaps it might be worth a try. However according to this: http://www.midwayusa.com/midwayusa/S...ed_threads.pdf
The max amount of torque on the repaired thread would be 23 in/lb (less than 2 ft/lbs).
Grab a booster cable. Hook one end to Negative of your battery & the other end to a bolt on your rear cylinder to confirm you have a good ground.
Check the wire that goes to your VOES located at the top of the engine between both cylinders.
Pull your plug wire & check it for damage or looseness at the coil.
Confirm that you have spark on the rear cylinder & swap your front & rear plug around.
One of those might get ya going.
Hatch.
Hatch.
Took me all day, but I got it started. Don't use longer bolts!!!!!! At least on the primary side. I put a .250" longer bolt in and it must have been hitting the valve top preventing it from functioning. when I removed the bolt, you can see the bottom 1/8 was chewed up. Put in a shorter one and it started. Ultimately I have to get a new lower rocker cover, the threads are stripped.
Joe
Joe
