pink ta tink tink-top end noise?
Well it's been a while but life is busy and bike has been parked with this issue. I'm trying to be as helpful as possible because I believe I found the issue with the bad noise my bike is making.
If your bike is making a sound that sounds like a small ball peen hammer hitting an anvil. I would suggest parking it immediately and checking out the lifters.
As much info that is on the net I had an extremely hard time finding any follow up for my problem. Plenty of people talking about a noise and plenty of suggestions, just no one coming back and explaining what they found.
Basically in trouble shooting I began to replace my lifters. Found I had JIMs Power Glide Big Axle lifters #2456-1. Roller was shot with lots of slop and the roller had flatish spots on it. Source of the cause and the noises. Going to try and post a video as a follow up. Hope it helps some one out there.
I had that happen with my first motor in my bike at 46,000 miles. The stock Harley lifters gave out. In my case, the needle bearings fractured under the repeated stress of running and just disintegrated and spread out through the motor. This happened on the front exhaust tappet, and was with the stock cam.
For the record, I heard the noise off and on for about a month, but It would come and go again, so I couldn't pin down exactly what it was. One day, the noise came back and wouldn't go away. By then, I figured out what it was, but the damage was already done. Ended up costing me an engine.
Uncle G.--how did you know the motor was junk? Did it take out a crank bearing or something later or did you just tear it down because of the metal going through the motor?
I'm going to put a new cam back into it...has a HQ-0023 in now. My lifter failed on the rear intake and cam is pretty badly scored. Motor ran good so going to put the same cam style cam back in.
I had a similar thing happen, I caught it early and was able to account for all the rollers.
https://www.hdforums.com/forum/evo-c...ing-sound.html
So you could say, it didn't cost me the motor right then and there, but it WAS the cause of the eventual rebuild. The top end was still fine. Ironically, the engine was still running fine, even with the worn pinion shaft, just some excess noise in the gearcase.
I guess if I were you, I'd still probably do what I did. Flush everything thoroughly (including the oil tank and lines and the passages in the gearcase cover) and hope for the best.
Only thing i dont understand is that the big bucks JIMS BIG AXEL lifters were designed to actually prevent this type of failure !?
