Speedo cable
The inner will probably pull out from the speedo end. Disconnect the bottom end as well, so you can check when twisting the top end that the bottom end turns freely. If all is OK lightly grease the lower half only of the inner to lubricate it (so the grease cannot get into the speedo head). These things can dry out, even rust up and seize in the outer and sometimes break. I protect the bottom end of mine with a tv aerial sleeve to keep the damp out. It's a snug fit but will slide on with a little Vaseline or similar.
Just lube it up all the way through with cable lube, and screw the upper end into the speedo housing, and the lower end into the speedo gear housing on the front wheel. It was pretty easy except for getting the upper end into the back of the speedo inside the "toaster dash" she has. On your bike the speedo is surely much more accessible than mine.
The rubber boot is a great idea for keeping the lower end free of road grit and water. I just reused the boot that was already on the old cable.
1993, 93, broken, cable, fxr, harley, lubricating, pulls, remove, replace, replacement, sleve, speedo, speedometer, sportster
