help!
Almost forgot...there are a couple different plug types....the part number I gave has the late style plug...not sure what style is on your SE module...I have an SE module on my '86 but needed a wiring harness to adapt it to the '91 and newer plug...I'll need to check tomorrow if I have the same SE module part number as yours.
Here is a link to a 7-to-8 pin adapter:
http://www.debrix.com/ProductDetails...ode=32-0085-VT
It sounds like there are 3 types of connections...the early barrel type used until '90....you need harness # 32408-90 to change to the 7-pin connector used from '91 to '93.
Then the 8-pin Deutch connector was used after '93 where you need the 7-to-8 pin adapter to adapt to the later style. And there is an adapter to adapt from the 8-to-7 pin style also:
http://www.debrix.com/ProductDetails...ode=32-0086-VT
Or you can just rewire it with the proper connector.
rel3rd
07-16-2009 09:00 PM
virtualmike13
10-03-2007 04:13 PM
