trying to fix base gaskets for good
Old 04-03-2010 | 08:31 PM
Moog Player's Avatar
Moog Player
Yeah, and easy on the throttle for a few MILES really helps to keep them from leaking as you come up to full temp.
Old 04-03-2010 | 08:47 PM
the_ogre25's Avatar
the_ogre25
As I already said I have always let the bike warm up until the rockers are hot to the touch and then easy for the first few miles, so I do not think that is the problem. I am hoping lapping the bases will at least let me know if the cylinders are not flat on the bottom.
Old 04-04-2010 | 06:30 AM
nibroc's Avatar
nibroc
I've had good luck with hylomar--absolutely no leaks
Old 04-04-2010 | 06:35 AM
prodrag1320's Avatar
prodrag1320
Originally Posted by lightweight bob
FYI - found out about it from a top fuel bike engine builder - Three Bond. Also makes
it for some bike manufactures under their name like Kawasaki. Only stuff that I
like better than Permatex Aviation when its gotta seal and goes through expansion
and contraction over and over. IMHO.
we set our nitro bike up with orings,like a TC.(we also set all evo rebuilds up the same way,0 problems or leaks).be very carefull useing sealents,with some,you`ll never get cylinders back off.if you have a leak with james steel,or cometic gaskets,you`ve got something wrong,fix it,dont just slop it up with something and put it back togrther
Old 04-04-2010 | 12:06 PM
Jim Kraft's Avatar
Jim Kraft
I agree EVORider; I have 23,000 on my 99, and so far not even a weep of oil anywhere. But I do let it warm up before I ride, and also don't get on it to hard for the first few miles.
Old 05-20-2010 | 12:15 PM
moblue's Avatar
moblue
6th Gear
wondering if ogre25 ever got his cylinder base leak fixed? did you lap your cylinders? if so, what did it cost you? do you know how much material you removed? did you have to compensate by using thicker base gaskets?
i have the same problem. replaced base gaskets twice (harley first, cometics second). neither fixed my leak. it never leaked before the rebuild.
i'm considering lapping cylinders and installing hayden oil fix along with a third set of gaskets. possibly using coppercoat or similar gasket sealer despite my local indy advising against it. not sure who's gaskets i'll pick this time. probably use the base gaskets that come with oil fix and get top and rocker gaskets.
any info you've learned that you'll share is appreciated.
Old 05-21-2010 | 05:42 AM
the_ogre25's Avatar
the_ogre25
I was going to update this thread in a couple days but this seems like a good time. Yes I did buy the lapping ring(about a $100) and lapped my cylinders, my guess is that I removed less then .005 of material as that is what the gap I had when using a straight edge on the base of the cylinder.
I used the Hayden oil fix as I already had it on there and a James metal base gasket top end kit. I also applied a very thin layer of gasket sealer on the base gasket(probably not needed but I wanted to make sure it wasn't going to leak). I torqued every thing back to factory specs.
I have put almost 500 miles on it this week after the gasket replacement, following my warm up practice to wait until I feel warmth from the rocker boxes before taking off, and then easy on it for 3 to 4 miles. I am VERY happy to report no oil leaks at all!!! I would like to thank all the people that responded to this thread and pm'ed me.
If you need any more details feel free to pm me.
DANNER55
EVO
03-11-2012 06:32 PM
cbaker1@farmersagent.com
Exhaust System Topics
11
08-31-2010 08:39 AM
tomtwix
10-19-2008 09:12 PM
BiggestDawg
02-25-2008 04:41 PM
turbo54
Oil Archive (no new posts)
01-04-2006 02:04 PM
Quick Reply: trying to fix base gaskets for good
