Fork air pressures
Old 03-19-2010 | 03:02 PM
hey stoopid's Avatar
hey stoopid
6th Gear
Default Fork air pressures
Hi you all.
Seems the air in my '91 fxr conv has leaked out of the forks.
Can anybody give me a pointer as to what pressure it is?
I do have aftermarket progressive springs fitted . Dont know
if it makes any difference
cheers
Old 03-19-2010 | 06:12 PM
sqdealgeorge's Avatar
sqdealgeorge
Pending on your weight Say 200 #'s 8psig
Old 03-19-2010 | 06:31 PM
1skrewsloose's Avatar
1skrewsloose
My 90 fxrs-sp shows 8-12, 20 max, depending on weight and how stiff you want the forks to be. Stock forks and springs.
Old 03-20-2010 | 07:28 AM
1st 96 ultra's Avatar
1st 96 ultra
I put a set of progressive in a bike a few years ago and not sure but seems like they recommended no air with there springs , might want to check there web sight
Old 03-20-2010 | 07:56 AM
hey stoopid
6th Gear
cheers guys
cant say what springs they are as they were fitted before i got the bike.
i.ll just try and see
the forks do bottom out so i'm assuming they need a wiff of air or something
Old 03-20-2010 | 06:46 PM
miacycles's Avatar
miacycles
Be sure to check the air each time before riding, that way you will get an idea of if or how bad the might be leaking. If they are leaking then track down the source and fix it.
Old 03-21-2010 | 06:13 AM
hey stoopid
6th Gear
yeah, know where the leak is now . pipe clip on the bars was done up tight and over time must have cut through.
have fixed it i hope and have whistled some air in there.
hopefully a bit of trial and error will do the do.
was just scared of putting too much air in and popping the system
thanx to you all
Old 03-21-2010 | 06:31 AM
RudeDog's Avatar
RudeDog
This thread came in handy for me. I have a buddy that just bought an '05 Road King and he needs air in his rears. I'll pass this information along. THANKS!
P.S. I have the bicycle tire pump and a low pressure gauge I bought for the 3 wheelers that will come in handy for this operation. Just in case anybody's wondering what to use to get it done.
Old 03-21-2010 | 07:49 AM
miacycles's Avatar
miacycles
Rude dog is right, hand pump only. There are a number of small hand pumps made just for this purpose and a lot of them have built in gauges.
Old 03-21-2010 | 08:13 AM
t150vej's Avatar
t150vej
I've not dealt with aftermarket springs at all, but OEM springs for that front end ARE different from air, to non-air ride models. So, you may not need any air at all, or a much lighter air pressure with the aftermarket springs... Just play with it and see what works for you.
Quick Reply: Fork air pressures
