Carb Question
Carb Question
When I purchased my '95 Ultra a few months back, it needed a new carb. One of the ears that holds the float in place was worn/cracked, and the mechanic at the local Harley shop said it couldn't be repaired. Anyway, I ended up buying a new Keihan carb from the Harley dealer, but there was a catch. My cruise control cable won't hook to it. I was told this before I bought it, but I was in a hurry to get the bike running, and didn't shop around for any other carbs. After a little rejetting, this carb runs great, but no cruise control. The difference in this carb and the original one seems to be that the butterfly is pressed on this carb, and the old one was held on by a nut, which also held the cruise control cable. Anyone else run into this problem with a newer carb, and if so, is there a simple fix to reattach the cruise control to this newer carb, or is another carb available that would work. Harley dealer says they do not sell one that will hook to my cruise. I guess everything is fuel injected now.
I found a site on the net that offers a kit that uses the standard H-D cruise control module, but it won't work with my carb. I guess if I ever do decide to put CC on my bike, I will have to get a CV carb on eBay or at a rally to do it.
One more thing for my wish list...
Yeah that's the post I have that won't work with cruise control. I would like to find an old carb with the right linkage and just switch the linkage to my carb... Oh well, will just have to go to some rallies or swap meets in the spring and look for one!
