Cam question.
Old 11-26-2009 | 11:47 PM
hatchetman's Avatar
hatchetman
Default Cam question.
Got a line on an Andrews cam marked ED-35. I want to pop it into my 88 evo 80 ci stock engine this winter. I cant dig up spec's on this cam but wondering if it's a step up from stock or am I building a rocket?? I just need a lil more snot out of the hole. Bottom end is lazy until I hit 2300 rpm than I have good throttle response as it sits right nowIf this cam will work, Do I need anything else like lifters, push rods etc to complete the job?
Thanks!
Hatch.
Old 11-27-2009 | 03:05 AM
blowe's Avatar
blowe
It's probably an EV-35? You can find the specs here:
http://www.andrewsproducts.com/PDF_files/CamEV80.pdf
And looking at this years price list it looks like that cam isn't offered any longer.
http://www.andrewsproducts.com/PDF_f...009-retail.pdf
I'll let the guys that know these things inside and out lay out the details but I think an EV-13 or EV-27 from Andrews or W-6 from Bob Wood would be better choices in your bagger.
Adjustable pushrods while you have it apart will save you some work in the future.
Old 11-27-2009 | 06:33 AM
prodrag1320's Avatar
prodrag1320
i agree,the EV 35 is really for lighter bikes with the power more in mid upper ranges.S&S .520 is a good torque,low end cam too
kirby
Old 11-27-2009 | 09:24 AM
hatchetman's Avatar
hatchetman
Thanks for a fast response! I was looking at picking it up this weekend but it isnt what my bike needs. I will print off this page for my shop wall info center!!!
hatch.
Old 11-29-2009 | 01:11 AM
woodnbow's Avatar
woodnbow
Default to answer your other questions...
If you've got over 35,000 or so I'd do the lifters at the same time.
Old 11-29-2009 | 05:58 AM
gsxrboy96's Avatar
gsxrboy96
When doing a camshaft, lifters are a must, if you havent bought that cam yet, check out the vthunder line up from comp, these cams make great hp and are quiet unlike the andrews grind cams. chad.
Old 11-29-2009 | 11:22 AM
98 FLHX's Avatar
98 FLHX
I can attest to the V-Thunder cams as gsxrboy96 said...
Great power, and suprisingly quiet....
+1 on lifters need to be changed, as well....good advice.
tpb857
Shovelhead
29
02-20-2016 01:49 PM
98hotrodfatboy
EVO
01-01-2015 01:46 AM
WG2011
04-09-2013 09:40 AM
wiksfxr
Shovelhead
06-02-2010 06:48 PM
mav7500
Shovelhead
12-25-2007 03:31 AM
Quick Reply: Cam question.
