a lil guidance from the guru's please!
I wouldn't do a thing with the engine 100 PSIG/cyl is OK The front end noise could be such things as the front motor mount a bad wheel bearing or a front tire with over 12K miles on it If the cam is orig I'd put in an EV-13 Andrews/ new torrington cam bearing/adj pushrods and ride it like you stole it!
I will check into an Andrews cam, i need barrel gaskets cause mine are weaping so I want to pull the barrels for that reason as well!
lots of thoughts on change this winter. I might pull the king pack to lower the profile, I have not yet decided on the origional fender with the light or leave the chrome one on. But the engine & the hidious rattle are my first target. didnt get a chance to fire it up today but I will tomorrow & I will try once again to isolate the sound!
jwyrem
04-27-2011 09:25 PM
