How to check swing arm/suspension problem?
I'm having a problem and looking for a little help. Was riding home last weekend on long ride and started noticing a clunking sound in rear when going over small bumps in the road. Also noticed when pulling in and out of gas station drive ways.
Also when applying rear brakes I felt a vibration. (pads less than year old)
And heard a clicking on some tight right turns.
I figured by the sound and feel that the swing arm bushings are worn. Put the bike up on the jack and everything feels tight. How do you actually check for swing arm wear? Any other suggestions on things to check?
95 Ultra 51k
95 Ultra 51k
A loose swing arm will handle like crap in corners. grab a buddy & while he pushes the rear wheel left to right, look at the swing arm where it bolts on for any play. I would almost guess a wearing rear wheel bearing. Check your rear rotor as well as your rear sprocket for loose bolts etc. I dont think its your swing arm. How many miles on it???
Front or top motor mount ? Pull the chrome caps off the swingarm axil and see if the trans axil nuts are centered in the holes I had a rear tire that was wearing on one side and after I took off the chrome covers I could see that the left nut was toward the bottom of the hole It turned out to be the top engine stabilizer
I was pretty shocked when I finally got a chance to look into this and found it was the motor mount. But when the rear tire hit a bump it sends the front of the motor down and transfers the shock through the frame. Really felt like it was more centered. But I'm thrilled that's all it is!
