The throttle cable on my '94 FLHTC needs replacing due to the cable cutting through the 90 degree bend in the tubing. It's a stainless cable of some type. Not sure what brand and not sure if it's the correct length. Anyway, I can't seem to determine the correct length for a replacement on any online site.
If you measure from the carb end of the outer housing to the other end where the metal adjuster goes around the outer housing the length is 37.6" . The stock part number is56327-90. Hope this helps.
Yes, thanks that does help. I had been looking at some Barnett replacements that referenced the same OEM number except the Barnett cable was 42". A Motion Pro replacement with the same OEM number was 37.5". Will the added few inches matter on the Barnett cable?
