Clutch Cable Adjustment
It shouldn't matter, but adjust the play warm if that's where it's acting up. Keep in mind that difficulty finding neutral is normal. That is, "They all do that, sir." And this can be improved significantly by changing the type of primary fluid after first making sure the clutch is adjusted properly, and not just the cable part, but the whole thing inside the cover. Your official H.D. shop manual will describe the procedure.
You could try switching to something like Castrol "Type F" automatic transmission fluid. It seems to make it a little better than using the regular HD primary oil. Energy One also recommends B&M Trick Shift but I could not find that brand at the local Advance Auto Store. Also, my manual states to be careful not to overfill the primary as that could make finding neutral more difficult.Mine is the opposite of yours, it gets better as everything warms up.
On mine, it also seems to work better going from 1st to neutral, and timing the move as you blip the throttle a little, as the rpms change it is easier to slide out of first. One time a lady that pulled in front of me at the gas station and asked if she took the spot I wanted at the pump because I was sitting there and blipping the throttle, now if I have trouble at the gas station, I just turn it off and put it in neutral before I start it up again.
Much like Hackd , I adjust the rod prior to adjusting the cable, but with the Energy One extra disc kit using a heavier clutch spring it still is not as easy finding neutral on mine as with the stock clutch setup. However, it's one of those little things that takes a little getting used to do, maybe the next guy would really have a hard time, but now for me it is pretty normal operation. It's interesting how many skills you develop to ride an older Harley - all part of the "Harley Mystic" .
I am currently running Mobil 1 ATF in my primary and Mobil SHC630 in the transmission. The M1 ATF was at Autozone. The SHC630 you have to get from Grainger's. It made shifting really smooth and finding neutral easier. Which one did what, I dunno, as I changed both at the same time from HD transmission oil and HD primary oil.
Chief101
11-04-2006 03:51 PM
2007, 93, adjust, adjustment, cable, clutch, davidson, dyna, energy, evo, harley, motor, motorcycle, replacement, xlh883
