how low to set idle?
When new, my shovel would 4-stroke on the front cylinder and 8-stroke on the rear, which gave it a very distinctive exhaust. Evos run more evenly - not so cool!
Another reason for keeping rpms up at tick-over is simply maintaining uniform crank speed. If the speed drops too low, the crank speeds up and slows down between each cylinder firing, which puts unnecessary loads into the engine, as well as it being short of oil.
It is much more cool to let your engine run free and smooth at the correct speed!
