How high do you rev your evo?
Old 09-12-2009 | 01:43 PM
super-snake's Avatar
super-snake
4th Gear
While there are several factors involved in torque/HP curves, with the EV-27 cam, my evo gets max torque at about 4000rpm and max HP just above 5000.
Old 09-13-2009 | 08:58 AM
dog155's Avatar
dog155
Depends on what I'm doing,cruising shift at max 3k,adreniline rush 5k,racing or proving a point, float the valves if needed.
Old 09-14-2009 | 10:46 AM
Nautilus's Avatar
Nautilus
I don't know, if the bike reaches max HP at around 4k, why would u want to rev it until the valves float?
smitty901 (12-09-2021)
Old 09-14-2009 | 01:31 PM
mjunk1's Avatar
mjunk1
Originally Posted by EvoRPMpowa
Bone stock motor with S&S Carb, Drag Pipes, Adjustable Ignition Module, and a EV-51 Andrews cam. Pulls great till 6500 and the rev limiter is set at 7000 which i hit a lot when im power shifting. Runs great with 10K miles...
You and I have a different definition of "bone stock"
Old 12-08-2021 | 04:36 PM
drifterawh's Avatar
drifterawh
4th Gear
that's not bone stock ?
Old 12-08-2021 | 07:20 PM
smitty901's Avatar
smitty901
No idea no tach. It lets you know if you getting to high it stops pulling after a bit you figure it out before it gets that high. Mine is 25 years old and stock. Carb has never been touched.
Old 12-09-2021 | 05:50 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
Old posts never die.
The following 3 users liked this post by V-Twins & Bowties:
Goose_NC (12-09-2021), mike131 (12-09-2021), Paintslinger16 (12-09-2021)
Old 12-09-2021 | 07:32 AM
Hudson_A's Avatar
Hudson_A
Maybe just a tad off-topic since I don't have a tachometer on my '95 fxsts, but I am curious about the rpm that I run and would appreciate some formula or chart that would tell me what rpm I am running using gear selection and speedometer. Like, for example, what rpm am I turning if I am in 3rd gear doing 45mph, etc...
My bike is stock
Old 12-09-2021 | 07:49 AM
mike131's Avatar
mike131
Maybe its just me, if you don't know when to shift your bike by the sound of the engine maybe the bike should go to someone else
Old 12-09-2021 | 08:54 AM
V-Twins & Bowties
My bike is stock
Go to Nightrider motorcycle site . I believe there is one there.
t150vej (12-09-2021)
Quick Reply: How high do you rev your evo?
