View Poll Results: Does a single fire ignition on an EVO worth the money?
Yes
29.17%
No
16.67%
Not sure
25.00%
If it ain't broke don't fix it, keep it stock.
29.17%
Voters: 24. You may not vote on this poll
Single Fire Ignition
It was ALL good
Switched out the ign because of ocassional erratic timing readings, even after verifying the VOES was properly grounded. I'd heard and read it'd make one smoother and I understood the explainations but was mildy shocked when I actually felt the difference. As far as sound, I noticed little/no difference after a few miles, just "at the moment" it was smoother too. Can't describe it any other way... but no, no life changing difference in the exhaust.
Addition; Just read the NightRider article and agree. I changed the entire OEM set-up to a nosecone version, adjusted the timing (static), per instructions and the coil for single fire - same plugs, 18 year old wires, no carb adjustments, no other changes.
Dual vs. Single fire
I was thinking of switching from dual to single fire....
I decided to go with a SE module [32596-96] and SE coil.
I also changed out the plugs and wires, and it made a noticable difference.
Here's what Nightrider has to say about the subject.....
http://www.nightrider.com/biketech/h...ionmodules.htm
Not saying that either is superior to the other, as some claim.
If so, I'd like to see the proof [before and after dyno sheets]
on the exact same motor....
It was ALL good
Maybe it's me, but until the bike is fully warmed up, she sometimes sounds like a cylinder is cutting out or missing a bit. After she is completely warmed up the engine does not miss a beat. Could have more to do with the cam profile and the fact that I never use the enrichener when first starting the bike.
Welcome to HDF. These guys are talking about Evo big twins, which came before twincams. Your bike is a Sportster and much later, made alongside twincams. So you are right and so are they!
