carb question
carb question
Hi, I have a '88 FLHTP with stock motor and carb, has 47000 miles on it, compression test resulted factory specs. Was thinking about changing the carb to S&S super e vs. changing to cv carb vs. rebuilding the stock carb. The bike runs pretty good, but dosn't have the immediate pickup it once had and will "cough" once in a while. Anyone with any suggestions would be greatly appreciated. Thanks for reading and have a great day.
You probably have a compliance fitting leaking a bit. That will cause a cough and reduced pickup.
I went from that carb to a CV and ran it (carb) stock for about 30,000 miles. It increased my MPG by 10+ and have tweaked on it a bit, still get 43 - 52 mpg. Nothing wrong with an S&S but I've never run one. From what I see and hear, they have more tunable circuits and not the overlap of circuits designed into the CV.
But I vote for the CV
shenork, I agree with the above posters and suggest that with a stock motor, keep the CV. It's highly tuneable, cheap, and you can put the $$$ you would have spent on the S&S into something else.
Even if you bump the motor you can still run the CV as 93 FXR says.
I have run a S&S E on a worked over 80" motor for 7 years and like it, but a correctly set up CV would get the same job done on my build; in fact I've recently sourced a CV off Ebay to play around with.
Just my thoughts, if you really want a different carb the S&S will work but your paying for capabilities you won't use on your stocker.
regards,
V2Evo
regards,
V2Evo
Received 8,422 Likes
Changed my old stock carb to a CV and love it. Also went with a Big Sucker breather, Andrews EV-27 cam and new lifters. like riding a whole different bike! I am not getting that great of mileage though, consistant 38 mpg no matter what my riding style. but the extra power was so worth it.
