rear wheel installation help
Anyone want to share the trick for getting the big spacer between the swing arm and the sprocket on a 90 FLHTCU? Try as I have, it just doesn't seem to want to fit. I'm lined up on the caliper side, but can't seem to get the sprocket side to work. Any help GREATLY appreciated.
mjunk1,
Are you running the original wheels or are you using 2000 + wheels. It doesn't matter I don't guess, i do it the same way. I usually do a wheel or tire change alone. I let the bike down almost in position, but put the spacer in between the bearing and the swing arm and then let the bike down in the position to put the axle in. I use a screw driver or a lineup pin to hold the spacer thru the swingarm so it doesn't fall out. This is not a good explaination so maybe someone else will have better skills at explaining their procedure.
later........................
My 86 has the axle going in from the left. I did this last week for my new Dunlop, so it's still fresh in my mind. I put the wheel on my hydraulic jack, in position. Then I put the spacers in place and jack the wheel up into position, push a 1/2" extension bar through from the right, jiggle it into the correct position and push the axle in from the left.
I gotta put the Sporty's new Metzler Lazertec on next.
Yeah, it's the biggest pain in the butt of working on one (to me)
With the wheel sitting in the swingarm, position the jack just high enough for the swingarm to be half-way covering the bearing centers. **** the top of the tire to the left and slip the spacer into the dish of the pulley and hold it at the bearing. Move the wheel upright and that will position it between the swingarm and the wheel - it cannot fall out. Then you can either pick the wheel up with your feet and hands till it all lines up, or let the jack down just far enough to get the axle started.
Remember though - the disc has to be lined up in the brake pads/caliper before the swingarm is low enough to even start doing what I just said.
Yep, it's just the monkey and the football - everytime........
Brilliant!
Buttersbeanball
10-29-2018 05:56 AM
VintageBiker
04-25-2010 09:53 PM
