Has anyone changed out the ECM, mine 96 RK - efi
Old 10-07-2009 | 12:02 PM
440racer's Avatar
440racer
Default 97-98 ECM Part NUmber
I just ran across this thread doing some research.
Does anyone know the part number and manufacture for the 97-98 ecm?
I believe the 96 is Magnetti Marrelli and the 97-98 is Bosch?
I have a 96 FLHPI and am planning to make the same swap before new exhaust & cams.
Old 10-07-2009 | 02:20 PM
2nd Mike's Avatar
2nd Mike
The part number is 32423-97B for the 97-98 programable ecm.
List is $384.00
CHD Is $307.20 plus shipping.
It WILL have to have a map installed for $150 from an HD shop for it to even start.
Old 10-07-2009 | 09:32 PM
2nd Mike's Avatar
2nd Mike
OOPS! I left out that it's still an MM.
Old 10-08-2009 | 10:43 AM
1997bagger's Avatar
1997bagger
Originally Posted by phat96
Robzuc97, with my 96, the best I can do is a revtech dfo, or other fuel managment devices that don't alow you to tune like you can with the power commander. I can't set up for maximum hp or to slow down the idle or to give it a slower lope.
Phat96, the idle screw is behind the air breather plate and usually has a hole in the plate to access it and not programmable with the PC3, slowing down the idle won't make a the dual runner M&M intake evo lope like a carb, just a characteristic of M&M efi. Making a M&M intake efi lope is possible (mine does) but takes alot of work, nerves and a tig welder.
saz
EVO
04-29-2015 07:54 PM
loopie
01-01-2014 05:18 AM
FastGraf
02-11-2011 12:11 AM
96roadking
EVO
03-27-2010 05:41 PM
hotammo
06-03-2007 05:37 PM
Quick Reply: Has anyone changed out the ECM, mine 96 RK - efi
