Upper end Ticking
Upper end Ticking
I have an 85 FLHTC. This is my first evo. It has about 40000 miles on it. I just rode it on a 500 mile round trip. On the way home it started to tick/clack at 4000 RPM or about 80 Mph. If I backed it off to 3500 rpm the noise stopped. By the time I got close to home I couldn't get over 3200 rpm without hearing the noise. The bike has the same power it always had and the oil pressure stayed the same. It starts right up. Does this mean I need to have the heads done? Or is there something I can do without tearing it apart? I've always had shovelheads so I am new to the whole evo thing. If that noise was coming out of my shovel I would get the heads done but I don't have the cash for that right now so looking for a cheap fix. any help would be appreciated.
You could have a lifter going bad, the early evo lifters have a history of failures. They will fail at the roller, which can cause serious damage.
40,000 miles is a good amount of miles for the “A” design lifters.
I recommend you pull the lifters out and toss them into the scrap pile, and buy a set of lifters from Harley.
The Harley lifters were upgraded in the mid `90s and are excellent.
I started typing and totally forgot the year/mileage posted.
Well I feel your pain. I've had a lot of help here but I'm about ready to get another engine. I've replaced the lifters, pushrods, rocker arm, checked side play in the rocker stand, instaled heavier oil pump spring, tried different weight oils upto 70 wt and still no fix. It will be quiet until it warms up then ticks like it has not enough oil pressure to keep the lifter pumped up. I've cleaned the oil passage screen the lifter block doesn't look worn.it has the noise coming from the front head and right at the exhaust rocker. AAAArrrrgggg!
Red, you could be hearing clatter from excessive gear lash between the cam gear and the pinion gear. It can be caused by incorrectly matched gears, or by a worn bushing in the cam cover. It sounds just like a clattering lifter,and gets worse when the engine gets hot.
Relative question, since we're all in the same boat....
Do you hear the same noise between the jugs, near the bases?
My story sounded much like yours, but I recently noticed that the noise is not quite as isolated as I thought.. Seems to migrate everywhere..
No just the top end at the front exhaust area, it is getting worse and it looks like I'm down to the valve seats need redone like I was warned of here before, I just can't get my head around that causing the noise but its about all thats left.
Word of advice - whether out of ignorance or greed many, if not most high-performance/race type machine bike shops WILL work around the issues, rather than addressing the actual problem, charging for "upgrades" with increased performance claims, yet still not take care of what was initially wrong - right Greg?
So, I've been teetering on this decision for a long time, mainly financial reasons, but have decided to "tool up" and start taking care of heads like they should be, without charging HD machine service or big fancy "race" shop prices. No Terry, I'm not advertising anything except my disgust with seeing SO many guys with rattling engines who spend big bucks for butcher jobs and still having a rattling engine when the dust settles.
It'll take me a couple months, but y'all get back to me....
