Why did HD build a motor to leak oil all over the place ?
Last year i purchased a 98 roadglide with 41.500 miles on it, all my hd buddies told me to buy an evo motor, so i listened. The crank case breather was hanging down and breathing oil on the ground. it had a screaming eagle air cleaner, i had the top end rebuilt last year new pistons,rings,5000 over on the cylinders,new cam,the stock air cleaner put back on. now it leaks/breathes oil all over the side of the motor. why would a company engineer a motor to do this. Had i have known this i would have bought a twin cam, but i hear they also have problems.bearings ? I am almost ready to buy a gold wing. any imput would be great, as for the engine.
Take the rocker box cover off, then remove the intermediate rocker box. Next to the umbrela valve is a 1/16" hole, drill it out to 1/8". This will help with oil coming out of the breather. If the engine was rebuilt, and the ring gap is too large you will get a lot of blow by and that will cause the same problem. Have someone do a leaksown test on the engine. With the little time on it since the rebuild you should have less than 10% leakdown. Any more and you start getting the problems you are describeing. Hope this helps.
I have a 90 tour glide and it doesn't leak at all. well maybe a little. I can wipe the bottom of the eng/trans and have a little bit of oil on my hand, but it is not enough to drip. I always thought this was a trade mark of a harley. your leaks seams more serious though. a goldwing has it's share of problems also. front tire cupping among other things. I would try to find the source of the leak and fix it. I also belive the evo is the best eng. harley ever built. I wouldn't give up on her yet.
The very reason so many bros.get into their bikes learning how to tweak them.For years with the total loss systems it was a right of passage.Leaving their mark.you can stop all the leaks Harley does not design their bikes that way anymore.Never forget they are still machines subject to things like that.It is all about proper maintainance.
Now I have no idea what the deal is, but last year I had oil leak down all over the side of my motor. This winter I took out the stock cam and had an EV27 put in with new lifters. NO umbrella valve from S&S was put in. Had her put on the dyno.1000 miles of running relatively hard and guess what? No more oil leakage! I didn't touch the top end either. Go figure!
