electrical problem-88'FXRS
Old 04-26-2009, 11:51 AM
sqdealgeorge's Avatar
sqdealgeorge
sqdealgeorge is offline
That inner primary is critical on starter alignment as well as the throw out of the starter gear onto the clutch basket ring gear Too far onto the ring gear the starter gear won't release etc I have a custom that eats ring gears ! (aftermarket inner primary )
Old 04-27-2009, 10:15 PM
lowglide88's Avatar
lowglide88
lowglide88 is offline
Thumbs up
well....I found the problem...it was combo of things... a bare wire underneath the gas tank...must have caught it when I put it back on...a loose connector the coil..but the biggest problem was I had two of the wires at the coil connected wrong(dumdum)...causing the timing to be off...got that all corrected and she turned over just fine....thanx guys for all your input.
Old 04-28-2009, 08:08 AM
harleyguy5571's Avatar
harleyguy5571
harleyguy5571 is offline
Great job lowglide88 glad you found the problem. Now get out there and RIDE RIDE RIDE BROTHER!!!!!!!
Old 04-29-2009, 08:10 AM
ozzie65's Avatar
ozzie65
ozzie65 is offline
"but the biggest problem was I had two of the wires at the coil connected wrong(dumdum)...causing the timing to be off."
OK, I am still having this issue, did the bike run even tho you had the wires connected wrong?
I have replaced my coil, so could this be my problem as well?
Old 04-29-2009, 11:55 AM
lowglide88's Avatar
lowglide88
It cranked over but it wouldn't run...it was firing on the wrong cylinder...soon as I switched the wires around ...big difference....did you test the coil?
Old 04-29-2009, 08:16 PM
ozzie65's Avatar
ozzie65
ozzie65 is offline
OK, my bike will run, in fact I have put over 1000 miles on mine already. Just have this starting problem........ not every time.
I had the dealer look at it, and it has them stumped. Their only suggestion was to put in a Crane timing system so I can delay that first spark, or put in compression release.
I am running SE heads with new jugs and pistons, running 10.5 : 1 compression.
still stumped
Old 04-30-2009, 02:35 PM
lowglide88's Avatar
lowglide88
If you don't have compression releases...that may be a good idea...before I did my engine swap my 80 inch EVO had S&S heads,10:1 comp. and an S&S 520 cam...I killed the hitachi starter and several batteries...I upgraded to the all ***** starter and the odyssey battery and did not have a problem..but even with that I was still considering comp. releases.
Old 05-01-2009, 08:01 AM
ozzie65's Avatar
ozzie65
ozzie65 is offline
I pulled the plugs last night, and the starter spins the motor with no problem at all. But...... the starter/solenoid would not disengage even after I released the switch.
Pulled the primary and the starter gear is binding up with the clutch ring gear. It almost appears that the it wont release until the motor starts and takes off the pressure?
Still puzzled, but it look like comp releases are a part of the fix.
daven9113
EVO
05-04-2018 08:22 AM
neverchekmail
Electrical/Lighting/Alarm
07-19-2017 08:40 AM
kngfsh80
06-03-2013 06:03 AM
radio915
Shovelhead
04-29-2009 08:37 PM
arizonapete
21
07-27-2006 10:39 AM
Quick Reply: electrical problem-88'FXRS
