Cam inspection help
Big Thanks fer the notes ..
Couple questions ..
I bought a lifter/tappet kit off ebay (Item number: 400036265932) and it includes all the gaskets and seals plus the high end cam bearing. It has new lifter blocks and the adjustable push rods plus tube seals. Got the kit for $289 and free shipping. Today i found out i lost the dam washer used for the breather gear and its not stuck to the cover as i already looked. Is that gear just a plastic washer that i could make and grind to depth ?
Do i have to replace the cam gear cone cover or the brass bushings ?
Also, i was thinking of using the old cam as i had no problem with it. The only problem was one of my wheeled lifters went bad.
HUGE THANKS for this forum and the folks who visit here.
Just go to the dealer and get the new washer. Put it down to not paying attention. Some things you don't want to mess around with making yourself, and cam/breather spacers fall into that category. Also, don't forget to check the endplay on the cam when you put it all back together. Oh, and you'll find the missing washer thingie as soon as you put everything back together.
If your cam looks good, that is, no wear marks on the lobes or bearing surfaces, I'd reuse it, unless you want a different one and have the bucks. The problem is that if one of the lifters went bad, they frequently take out the cam. I really have never heard of a lifter going bad in any vehicle and not wiping out the cam, but whatever. I dind't look at your vids.
Hey` Dock` .. good to hear from you again ..
I found my dam washer from the breather gear, it was in the
oil container where i drained the oil when opening up the case.
Been reading here on the forum and in my manual of the measuring
of the cam and the breather so no problems there. My only worries now are going to be adjusting the push rods as im afraid im going to F$#k them up.
aaron
aaron
aaron
aaron
