Enclosed Chain conversion update.
well he's lost its also a 4 year old thread
i have a 81 FLT that is a shop loaner and we looked at converting it, this is what i found having a 1981 and a belt drive 1985 FL at the same time with the same stuff apart
the inner primary is all together different - it takes a 22 tooth chain sprocket its almost 3 inches different in diameter for the bely sprocket and it does not fit in the location -- the trans main shaft is different - the rear wheel is different - that makes the brake different as its easyer to replace it than mod it - some outer primarys are the same - some of the starter stuff will exchange - makes it a wet clutch - so oil lines become different the vent mostly - in 1983 they changed the inner primary O Ring to a much larger size < this is the spot most shops bail on this idea - as the engine blocks are different in the o ring groove - SURE anything is possable if you have a wad of cash and no brain to say stop whaat am i doing --
hope that helps - i dont think he did it after all -- johnzjzj
I am in the middle of this conversion on an 83 FLHT...I am doing MANY other mods at the same time...so a lot of what I did is not necessary. I wanted to move the battery under the seat at the same time, so I bought the transmission, inner/outer primary, clutch,starter, compensator, and all other priemary parts from a 94 touring bike. I am changing to a 200 rear tire and bought a 2006 rear brake. The only reason I needed the trans was to get one with the oil tank under the trans to move the battery. I mocked it up...pretty much a bolt in operation...and not a lot of cash with the used ebay parts.
i look at what you are doing and Bravo young fellow - great idea great execution and it will to those who are in the know know what you have done is very special in deed -- good luck --jz
I think this place has the conversion down, the kit runs $850.00 and says it comes with everything you need. My bike is a 1984 FXRT with a EVO, 5-speed and the enclosed chain. http://www.karata.com/final.htm
streetfighter06
07-14-2011 12:45 AM
