oil fill mark
Yep, that's it.. Gotta leave some room for venting.
Course when oil is hot it, level will be a bit higher..
On my 94 FB, after having bike up-right knowing it is properly full, I put it on kickstand & then made a small full-mark on dip stick at that level.. So I can easy check with bike on kick-stand. & know I'm good to go..
Received 75,019 Likes
2.5- 2.3/4 Qts. will do you just fine, and add as needed..is how I do it.
Better to be a little under than over..On your dipstick, it should read between the two lines that are on the stick, and not over the top line, then you got too much, and under the bottom line, not enough. Hope this helps.
I don't know what kinda dipstick you got but everyone I've ever seen has 2 lines on the stick. It has a full line at the top of the stick, and it has an add line at the bottom of the stick, or grooves if you will. That comes straight outta the owners manual and I just looked and it is clearly diagrammed to show that on Pages 152 & 153 of the H D Owners Manual for 1999, last year of the evo softails. Check it out.. Seeing is believing....
