evo parts help
thanks,im now going w/ the oil fix and james base gaskets,cometic head gaskets.stock pistons and new rings. hone the jugs(myself)ev-27 cam w/ torington(think thats it,)bearing. new lifters(have adjustable rods now)and send the heads out to r&r cycles(very good shop here in n.h.,,). have them port ,polish, and shave the heads a little , not much. that will keep me and my cash tyed up for some time,,thanks for all the input !!!!
The oil fix is a way to vent the crankcase so the oil isn't so pressurized where it doesn't need to be, thereby preventing some leaks.
If you were referring to the brand name "Hayden Oil Fix" it comes w/base gaskets & it's magic: is a nipple like tube that gets placed in the return hole of the motor case (F & R), only goes in 1/2 way, so the cylinder accepts the other half. This prevents oil from even getting near a base gasket, And really works well avoiding base leaks.
well now i have a real problem. pulled the cam cover off and the cam(bearing surface in case) was junk.. lifters so,so(some marks,scuffing) but,, i found where all the metal shavings are from,,,,,,the crank bearing can slide 1/4 in out of the case till it hits the retaining ring, the retaining ring is all ground down on the outside edge..like the crank is 1/4 to far out from the caes,. the ring is in the grove(like it should be) i think the ring is grinding on the oil pump grear(?) It IS grinding on something,, the oil pump drive is not worn or sloppy.the cam is(was) not hitting it. now wife thinks maybe time for a new bike!! Or get a new engine,,, im thinking el bruto, or ultima... ill update as i go.. thanks for all the help....
Sounds like the pinion bearing is worn out (if it actually slides in and out easily). Sprocket shaft bearing is probably well worn also.
Sprocket shaft bearing is 28.00. Pinion bearing 50.00 from HD about 20.00 if you know where. The pinion race is 55.00, unless it will "clean up" to an acceptable oversize. Downside - the tool to do that is 800.00 (yes, I have one) Cam 140.00 (+ or -), lifters 140.00, rod bearings with pin and lap the races about 300.00 (would be less except I don't have that tool dammit). Gaskets and seals 100.00. Another 50.00 on the heads if nothing out of specs there. Pistons, rings, wrist pin bushings 150.00 plus boring and honing about 200.00 (on the average)....
About 1200.00 in parts and machine shop charges for a like new engine. Unless your heads need seats and guides, but doubtful they be worn that much, Maybe exhaust guides...
Im talking it over w/ "the boss" mybe now is the time to get a full sized cruzer w/ hard bags and a nice seat for her..she brought it up?!?!?!?!i bought the bike before we met, and a wideglide(even fully loaded w/ bags and upgraded seat ,windshield and others) is not as nice on long rides as a bigger 2 up bike.we"ll see how it goes,, for now its on hold till we make a $$$$$ choice as to what to do,, Ill be around , but dead in the water for now,, thanks for the info mp and t150vej and others,, i need a beer!!
