Springer Questions
Springer Questions
I've got a 93 FXSTS that I purchased used a couple of years ago. It's got the original springer shock and original springs. Have any of you springer owners replaced the springs and/or the damping shock?
Since the bike is 15 years old, I'm wondering if they could be worn out. Having never ridden it brand new, I don't really have anything to compare the "feel" of the front end to, so I don't know if those components are worn out or not.
I've been thinking about replacing the front shock with a Progressive Suspension shock, but I haven't been able to find anyone that sells a replacement spring kit. Anyone know where to find one?
Since the shock is about $150 and I'm assuming replacing all the springs is at least that much, would this be worth doing? Or would it not be a noticeable difference, and I should just ride it as-is?
1993, 93, damper, davidson, end, front, harley, knucklehead, progressive, replacement, shock, springer, springs, suspension, worth
