Voes test anyone?
VOES problem?
I'm riding a stock (except for mufflers and a re-jetted carb) '87 FXLR. It only has 5600 original miles. Just yesterday, after some back roads and about 10 minutes at highway speeds (70-80) once I got to the end of the off-ramp my idle was fast and it had hesitation when rolling the throttle. I checked for loose vacuum lines and also loose wiring to the VOES but found neither.
Would the VOES cause the idle to speed up if it were going bad (or maybe it is...) and cause hesitation in the throttle?
Pete
Pete
Pete
Pete
Also, considering the year/low mileage, it's possible the carb could a good cleaning and replace the accelerator pump. A bad accelerator pump will display those exact symptoms as well.
