Cam Bearing-95 FXLR
Old 08-18-2008, 06:59 AM
Terp84Alum's Avatar
Terp84Alum
Terp84Alum is offline
Default Cam Bearing-95 FXLR
My brother has a 95 FXLR and I think he spun a cam bearing over the weekend. Can anyone shed some light as to what to expect with respect to the repairs? We have an event to ride to on Sept 10-14. Is this going to be a problem? Thanks
Old 08-18-2008, 11:38 AM
t150vej's Avatar
t150vej
t150vej is offline
Received 1,813 Likes on 1,176 Posts
Most likely messed up the cam or more correctly, the cam messed up the bearing. If it's not eaten away too much of the right engine case, you're OK. If it's a little sloppy, short if being able to wiggle the new bearing with your finger, use Loctite 648 Retaining compound. If you can't find it locally, use Loctite 680 Sleeve Retainer compound.
Good luck
Old 08-18-2008, 06:32 PM
sqdealgeorge's Avatar
sqdealgeorge
sqdealgeorge is offline
If it is the cam bearing (hopefully not) replace it with a torrington This bike came stock with a INA
Old 08-18-2008, 07:30 PM
Terp84Alum's Avatar
Terp84Alum
Thanks. What are the chances that there is peripheral damage to other parts of the motor. If it is just the cam and bearings, I would consider him fortunate. He's already thinking about the HD remanufactured motors.
Old 08-18-2008, 09:11 PM
keye's Avatar
keye
keye is offline
I have a 97 Road King and I just went through this horror...needle bearing went in the cam case resulting with the cam and bearing getting screwed....I knew there was a problem so I parked her asap 950 dollars later and a bill from Harley Service and now I am back on the road.....where you need to be careful is on metal filings travelling throgh the motor...and remember that the oil pump or better yet the oil gears are rite there...if metal gets into there...well you get the idea...it turned out to be a 3 day fix and considering everything, the price was not very much do not start the motor
Old 08-19-2008, 12:14 AM
t150vej's Avatar
t150vej
t150vej is offline
Possibility of other parts damaged is 50/50 (maybe, maybe not)
The HD EVO Reman program is great, but tear it down first. It would be a shame to drop 2700+ if all he needs is a cam and bearing, ya know? The cam I pictured earlier had 5000 miles on it and the the bearing looked like new, despite the hardface gone of the bearing surface - no further damage to the engine.
If it were mine.... I'd send it off if the cam bearing bore of the case is ruined (HD will repair or replace the case - same price) If the bore is good and there's no damage to the oil pump, fix it at home.
Old 08-19-2008, 07:21 AM
Terp84Alum's Avatar
Terp84Alum
Thanks. The bike also has oil leaks at the base gaskets and the dealer wants $600 just to fix those. If you're talking $1000 to fix the cam/bearing and $600 for the base gaskets, the reman is probably the way to go.
Old 08-19-2008, 11:25 AM
Terp84Alum's Avatar
Terp84Alum
Any idea as to where to buy a Torrington bearing? I've Googled and come up empty.
Old 08-19-2008, 01:18 PM
sqdealgeorge
J&P Cycles P/N 431-429 Phone # 800-397-4844 Hopefully you need the tool to extract the old bearing meaning the case hole is OK
Old 08-19-2008, 03:00 PM
Terp84Alum's Avatar
Terp84Alum
Thanks. I kind of feel stupid. I went to J&P's site. The dealer is doing the repair.
Quick Reply: Cam Bearing-95 FXLR
