FXR
RE: FXR
 \\;You can \\;swap the same common years , after that you would looking at gear sets only but with a clutch change too. If you want the splided shaft. \\;I am also try'n a get around this swap. I want to do a 6 speed \\; the biggest problem i have found is the ring and pinion gear for the starter. more than just the parts swap. The other way is a complete tranny/primary \\;,late evo and that is out of my cash founds. I have been told that unless your gon'a flog it that a primo clutch should take care of the week link ,the stock clutch.
Fxr6164
03-26-2014 06:16 PM
