sealing case with block seal?
is there any block seal you can add to your motor to seal a cracked case I will have to pull the motor to jb weld it and got a run coming up just want to make it through the season then a fresh 1340 from harley let me know I really appreciate have this site and you guys help on harley questions and challenges
RE: sealing case with block seal?
Exactly where is your crack?
Never heard of any magic formula \\;to seal a cracked block or case. Years ago, Bar's Leaks used to work pretty well on a small cooling system leak for awhile. Is there anyway you can get a Dremel tool or something similar into the crack to clean it out and then try the JB Weld without pulling the engine?
If not, then it looks like pulling the engine and your \\;JB Weld solution would only be a temporary fix at best. If you have to pull then engine \\;then have the crack \\;welded if possible. A good weld could also be a permanent repair.
