Click.....click......nothing....
Old 07-02-2008, 09:32 PM
Jinxie's Avatar
Jinxie
Jinxie is offline
Default Click.....click......nothing....
Hi
My 89 FLH has been giving me some recent troubles. The starter being one of them.
I havent run the bike in a week or 2, so when I started it, it was a click, click then cranked and started. Once I had it running, I let it run around 2500 rpm for about 20 minutes or so. After shutting it off, it would just click and wouldnt start. The battery was charged about a week ago. This problem has been ongoing for awhile, but I could always, eventually get it started. Now it wont. The charging system is new(coil in primary cover). I have full voltage on the + wire going to the solenoid, but nothing coming out when the solenoid clicks. Are the solenoids serviceable or replaceable?
&nbsp\\;
Thanks
Old 07-02-2008, 11:52 PM
cdnrider's Avatar
cdnrider
cdnrider is offline
1st Gear
Default RE: Click.....click......nothing....
&nbsp\\;figure out your bike? I have a 1991 fatboy with the same problem........&nbsp\\; click click , it would turn over&nbsp\\; but not start now it won't even turn over.......
curious if you&nbsp\\; got your figured out.
Old 07-03-2008, 07:02 AM
sqdealgeorge's Avatar
sqdealgeorge
sqdealgeorge is offline
If the starter motor is clicking it usually turns out to be a weak battery Before starting again get a good jump from a car bat to see if it now turns over like it should
Old 07-03-2008, 08:33 AM
Doc 1's Avatar
Doc 1
Doc 1 is offline
DO NOT use a car battery...the Amps are way too high and you&nbsp\\;are taking a chance of damaging your system. Granted the clicking comes from a bad battery or a bad hold in contact in the selinoid. If your battery is two or three years old replace it and check the voltage out put of the alt. you should read 13.5 to 14.2 on a volt meter at the battery at 2000 rpms.
Old 07-03-2008, 08:42 AM
im's Avatar
im
im is offline
would this link help you?:
http://www.expertvillage.com/video/1...attery-two.htm
Old 07-03-2008, 08:49 AM
im's Avatar
im
im is offline
this link is to bike bandit..just pick the bike then section you want to see diagram then enlarge/zoom..the list of replaceable parts is on the bottom...i find that batteries are ussually good for about 3 years with-out a battery tender in use...you may have full voltage but NOT enough amps to start do to bad battery or the ground or (+) could be loose ...could you have battery tested? or maybe just replace battery..let us know.
&nbsp\\;http://www.bikebandit.com/harley-dav...1989/oem-parts
Old 07-03-2008, 08:54 AM
Bossman1's Avatar
Bossman1
Bossman1 is offline
Battery solenoid or connections!!!
Old 07-03-2008, 10:40 AM
mjmangus's Avatar
mjmangus
mjmangus is offline
Replace the battery
Old 07-03-2008, 08:08 PM
sqdealgeorge
Doc 1 take a break it not that bad I've done it for 30 years !
Old 07-03-2008, 08:09 PM
Jinxie's Avatar
Jinxie
Jinxie is offline
The majority seems like the battery is dead. I would have thought that once the bike was running and idling, it would charge the battery. Afterall, it did start under its own power. Could the headlight and running lights created more of a drain than the alt puts out? I havent checked with a volt meter yet, but should the battery be charging at idle speed? What is correct idle speed?
&nbsp\\;
Thanks
Quick Reply: Click.....click......nothing....
