93 wide glide / inner primary
Old 06-29-2008 | 10:16 AM
jimnc's Avatar
jimnc
Default 93 wide glide / inner primary
&nbsp\\;hello all.&nbsp\\; My good friend has a 1993 wide clide that has a cracked inner primary case. all the dealers here in southern
N.C. tell him its not avaible .? they can get them up to 90 and after 94. has anyone changed theirs before if so were can we find one&nbsp\\; thanks alot.&nbsp\\; JIM
Old 06-29-2008 | 11:05 AM
Mr1986FLST's Avatar
Mr1986FLST
Default RE: 93 wide glide / inner primary
Here is what appears to be aftermarket primary case I saw on ebay:
&nbsp\\;
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&amp\\;item=260256646061&amp \\;ru=http%3A%2F%2Fmotors.search.ebay.com%3A80%2F% 3Ffrom%3DR40%26satitle%3D260256646061%26fvi%3D1
&nbsp\\;
In case the link doesn't work the item number is:&nbsp\\; 260256646061
&nbsp\\;
Anyway, I have not purchased this primary case but I am looking for a new inner primary for my bike too, '86 flst.
Old 06-29-2008 | 12:45 PM
dog155's Avatar
dog155
Seems odd you can't get it through the dealer.Ebay is your best bet!&nbsp\\;
Old 07-05-2008 | 03:31 AM
mjmangus's Avatar
mjmangus
My son owns a 94 fxstc and cracked the outer primary cover.&nbsp\\;\\\\\\; The parts are out there you just have to be patient.&nbsp\\;\\\\\\; He found his at a local indy.&nbsp\\;\\\\\\;&nbsp\\;Your friend&nbsp\\;might bring his old one along to see what the difference is.&nbsp\\;\\\\\\; It could be something as simple as grinding some internal casting.&nbsp\\;\\\\\\; Good Luck
Old 07-05-2008 | 01:57 PM
Dr.Hess's Avatar
Dr.Hess
Depending on where it's cracked, it might be fixable.&nbsp\\; The 79 FLH inners cracked around the transmission shaft bearing and that's junk at that point because any welding will distort it.&nbsp\\; If it's cracked somewhere else from a wreck or something, that can be fixed to good as new.
&nbsp\\;
jurgie
05-21-2017 08:11 AM
trainedkilla
09-11-2013 11:39 AM
goosehead
07-29-2011 10:56 PM
nkauf21
06-01-2010 06:56 PM
buzzpat1
06-29-2009 04:32 AM
