starter clutch
Old 06-18-2008 | 09:07 AM
ssls6's Avatar
ssls6
Default starter clutch
how hard to replace the starter clutch
Old 06-18-2008 | 11:21 AM
extech's Avatar
extech
Default RE: starter clutch
It's not bad, get yourself a service manual, it will familiarize you with everything else too.
Old 06-19-2008 | 06:09 AM
dog155's Avatar
dog155
Other than having to take the outer primary cover off,to get&nbsp\\;the starter&nbsp\\;out, then pull it apart.Not a bad job!
Old 06-19-2008 | 02:39 PM
Jonnyrod's Avatar
Jonnyrod
Pretty simple job. Make sure after you get the case bolts out before you separate the drive housing, hold the starter with the drive housing down and the starter motor up. This will keep the idler gear,bearing, and cage all together. Additionally I would also pop the end cover off the solenoid and inspect the plunger and contacts while you have it out. Better to do it while it is already out if it may need it soon anyhow.
95 Ultra
EVO
12-16-2012 09:03 PM
Mike5959
07-19-2009 08:17 PM
hoodlum
05-21-2008 04:15 PM
ACE75
06-11-2007 02:19 AM
DGlide04
Exhaust System Topics
08-27-2006 11:32 PM
Quick Reply: starter clutch
