air cleaner for 90 lowrider
I need a new air cleaner for my bike I just got, it is currently missing some parts. What is a good one to get...and is there that much difference between a 90 evo engine and a 91 evo engine? I cannot find any air cleaners with brackets for the 90, the start at a 91 and up. help...
RE: air cleaner for 90 lowrider
ebay is a good place \\;to start if there are no swap meets near you.
'90 thru '99 will work, but the backing plate of the 94 and later has larger mounting holes to the heads for the breather and will take a little engineering to make work.
Some models used a plate that the air cleaner bolts to, then the cover screws to the cleaner element.
Regardless, buy the cheapest one you can find, because you'll need a new element anyway and I don't care how sexy looking or fancy, you can't get any more air through the carb than a stock setup will allow.
