Leaking Oil After A Hard Ride
RE: Leaking Oil After A Hard Ride
ORIGINAL: 89 FXRS
It is beyond me why it seems so many use the same oil in all three too. The motor call for a 50w basically, HD has called for a 50w for over 90 years. The primary needs a thinner weight 10w or 20w max, ATF sounds perfect. The tranny calls for a 75w like your manual tranny on your car. To be honest HGM I am tired of talking oil weight. You are right, I am right. They are wrong and some will argue with usthat we are wrong past common sense. Go figure.
ORIGINAL: HGM
Got a blanket question for you though... It seems that everyone else is good with it too, but I'm curious why you would run 20-50 in all three holes?? It seems that it would be too thick.. I'm a car guy, by trade, and would never think of running a heavy oil in a manual reansmission because of engagement concerns. Also, why would the primary need a thick oil to lube the chain? Seems to me that an ATF would be a better choice for the trans and primary... Its a little off subject, but I'm just curious, plus, you'd be able to tell what was leaking..
ORIGINAL: HGM
Yea, it seems odd.... BTW, Ford, for example has used ATF in their manual transmissions for over 20yrs..
Thanks for the info.
1941ratrod
05-29-2006 08:06 PM
