speakers 94 flhtc
speakers 94 flhtc
hey all
riding season has been here for a month bout time
anyway need help.94 flhtc.while ridding last month
noticed speakers were not worth a dam on highway
i like my radio sometimes.anyway is it possible to put
the hogtunes speakers in with the 77047-98 adapters
and if so what is involved.
thanks for any and all replies
ride hard and ride free
gear
gear
RE: speakers 94 flhtc
The older stock Harley speakers were 8 ohm whereas the newer speakers tend to be 4 ohm which give you a more output power. I ran 4 ohm speakers with my stock Harley radio and it worked OK. J&M has 4 inch (4 ohm) speakers that are replacements for older stock Harley speakers . Another thing you can try is regular 4 inch (4 ohm) auto speakers. I switched to the Biketronics kit and now looking to try 4" Infinity Kappas which are 2 ohm , as the newer Sony radios can handle 2 ohm speakers.
The older stock Harley speakers have two different size terminasl , you may need to change one of them if you go to something other than Harley - the J&M speakers has the correct size terminals for older Harleys and includes new ones to change your wiring if you have already switched them to something else.
I did see a guy that placed 5.25 speakers in the glove boxes ( lowers) , and they sell 5.25 inch speaker pods to mount to the tourpak, but I think tourpak speakers are a waste of time if you ride 2 up.
on edit: If you go from 8 ohm speakers to 4 ohm speakers you will hear a considerable increase in volume .
Biketronics can set you up. Installing the whole deal on my buddies 90 this week. I've gone thru all the install notes and it is very easy to wire up.
For mine - I run a solo seat most of the time - so good speakers in the fairing are a must.
A Pioneer am/fm/cd with IPOD cable and IPOD Nano feeding 4 J&M speakers in the front fairing works absolutly awesome.2 speakers go in the stock location , then 2 speakers go right next to them. Need to work the inner fairing to fab the mounts and get the speaker faces, but it is definitly worth it to have 4 - 60Watt speakers blasting at you on the highway.
