petcock/ fuel filter
Just curious about this. I was sitting next to my bike enjoying a cold one I looked at the glass fuel filter and it was full about 10 minutes later it was empty. is this normal? I have a manual petcock that is turned off and a new makuni carb. If this isn't normal how do you prevent this?
wils
wils
RE: petcock/ fuel filter
If not between the cylinders, where else can you put the inline filter? On my '90 Ultra the petcock is towards the left front, close to the rear of the front cylinder and the fuel line goes almost straight across to the carb, if I added an inline filter I would have to loop it around the horn and VOES and hope the bend to come back in between the cyclinders was not too much. The other alternative would be to put it between the cylinders risking vapor lock. I bought a new, fancy Pingel filter but never installed it.
