this is my first harley bike ever so if i sound stupid i am, but my question is what kind of gas should i use in my 98rk premium or regular. thanks for any help
even with gas prices soaring every day. just spend the extra dollar at each fill up and run the good stuff. it cost me 16 bucks to fill my bike on high test. that extra dollar ain't gonna kill ya.
Run 87 octane....the EVO was designed to run on this stuff. The exception was the 1995-1998 EFI EVO though as these were designed to run on 91+ octane.
If the modifications were made to the engine like raising compression....then one probably should run higher grade of gasoline. A little pinging from taking off from a stop isn't going to hurt anything either.
If the bike does not ping under normal conditions and the bike is properly tuned...just run 87.
Suggestion! run a tank of 87 Octane if it does not ping your Golden,if it does step it up a notch.No need to run anything higher than the motor needs.Good Luck.
