brake fluid
02-18-2008, 06:16 PM
brake fluid
how often do you guys flush your brake fluid?
02-18-2008, 06:17 PM
RE: brake fluid
how often do you guys replace your brake fluid
02-18-2008, 06:30 PM
RE: brake fluid
Dot 5 every five years When you fill the master cylinder suck out and put in the same amount no more
02-18-2008, 06:48 PM
RE: brake fluid
darylnj,
If you are using DOT 3, it is recommended that it be changed every two years.
02-20-2008, 02:13 AM
RE: brake fluid
Complete change every two years, even DOT5 which I use in my Glide. Flush (or bleed) the system through until clear new fluid comes out. Most brake fluids are hygroscopic, which means they absorb water over time, one of the reasons they change colour. New fluid good - water bad!
biketroll
06-02-2021 11:00 AM
EasTexUltra12
07-14-2014 09:21 AM
bikeguy1961
09-23-2011 07:48 AM
emece
Wheels/Tires
07-15-2011 08:44 PM
oldtech
Wheels/Tires
02-02-2010 05:48 AM
