98 evo, carb needle question
RE: 98 evo, carb needle question
I do believe you can add washers to raise it up if necessary. If I remember right they are #4 copper washers available at any hardware store. Somebody correct me if I am wrong.
I actually went with an 88 sportster needle instead of raising mine and this worked perfect.
ssls6,
There is all kinds of modifications you can do to improve that carb. Check this site out......evrything you want to know about V twin performance.....
http://www.nightrider.com/biketech/hd_cv_mods.htm
later...............
ORIGINAL: 96 Wide Glide
The needle that I took out of my cv carb was red, and it looks like the washer position is adjustable. Is this not the stock needle? I replaced it with the 88 Sportster needle, which does not look adjustable without adding washers.
Cheers... Ben.
Cheers... Ben.
