I have a 95 dyna glide. I run 100/90-19 metzler me 880 front tire. Manual says 30 psi. My front tire has lots of cupping on the tread. H-D service manager says the tire should run at 42 psi, because thats what the side of the tire says. I understand that the tire shows maximum psi that the tire is capable of handling, not what is recommended. I aired it to 38 psi, but didn't like the way it handled. WHAT DO YOU RUN IN YOURS ?
Go to the Metzler website and input your bike. It'll tell you the recommended pressure
Ride safe and check your pressure often
Bubba
I agree with Bubba. You should always go with the tire Mfg's recomendation for your vehicle. In this case your bike. The reason being that this particular tire may have a different composition than the factory and the factory tire pressure recomendation may cause wear.. I wouldnt go with the side wall recomendation unless you are to full load or have yet to figure out what it should be set at.. If its feathering, obviously its not right. You could play with the pressures to find the right PSI, but that will cost you money.. I'd give them a call..
