Best stator replacement
RE: Best stator replacement
I don't know if any are "superior" but have seen Accel items with a lifetime warranty, so that has to be worth something. Afterall, the technology for alternators/regulators isn't new, so all should work well.
Is your current stator bad? If you want more juice, you could change out everything to the 3 phase 38Amp system. Moto-Electrix is an ebay seller that has a full kit and great feedback.
I'm sure there are lots of options.
I've had some bad experiences with Accel products lately. Maybe just my bad luck, but I'm staying away from their stuff for a while. I've had good experiences in past, however.
With the stator, it is the work involved to replace the thing more than the stator itself. Personally, I would go with whatever the "best" replacement available from HD is, and of course, put on a new matching regulator.
ORIGINAL: Dr.Hess
I'm not trying to push HD stuff just because I work at a dealer but in all honesty I've installed lots of different brands and never had any good luck with the aftermarket electronics. Stick with the HD stuff......
And like the other post said replace the regulator and stator and STATOR BOLTS .
The reason I asked the question was that I had also heard that the HD stators where better then the aftermarket butI didn't have any first hand knowledge on it. I haven't asked at the dealer if they even have them available for a 1990 still. My guess is no but you never know whats in the back room.
My charging system was working ok but the reg. plug became loose from the stator plug.I purchased one of those clips to hold it together and that helped. My son took it for a ride(from Florida to GA,Tenn and NCand back) and said it stated acting up a block from home when he returned. I was glad he didn't have a problem on his trip but don't want to fool around with a old stator and reg.
The stock stator on my FXEF grounded itself on the engine case at 50k miles. I replaced it with an Accel and it's held up fine for 47k more miles.For regulators, I've used Accel regulators in the past, but after frying two of them, I now use the cheapest ones I can get my hands on. The current $29 regulator has been on the bike for the last 25k miles when I was going through them about every 10k or less miles.....for weird stuff like worn wire insulation and it shorted out on the frame (2), bad battery tookone out.....
I also have a 90 Ultra and have been considering replacing the charging system. At idle with all the lights, etc. going my alternator output drops and the turn signals shut down. Recently found an older article by Joe Minton that addresses Harley alternator choices. He says that the older evo charging systems are not as good as the new models and his conclusion is if you need more juice install Compu-Fire's three phase system. It is a little pricey but Minton is rarely (if ever) wrong. Says it outputs 25 amps at idle and 40 amps above 2800 rpm. The article is in the June 2007, American Rider mag.and is quite convincing.
Steve
Steve
