New to me 94 Wide Glide
Old 10-25-2024 | 09:42 AM
Bubba Zanetti's Avatar
Bubba Zanetti
I thought 91-95 were all pretty much the same and interchangeable. Guess not...
mmmatt (10-25-2024)
Old 10-25-2024 | 09:44 AM
Tailbreaker's Avatar
Tailbreaker
Looking at the pic of your bike, it looks like the head pipes may need to be loosened and readjusted. Could be an illusion due to angle, but I'd try it to see if it gives you enough clearance.
The following 2 users liked this post by Tailbreaker:
mmmatt (10-25-2024), Yankee Dog (10-25-2024)
Old 10-25-2024 | 09:48 AM
Bubba Zanetti
Originally Posted by Tailbreaker
Looking at the pic of your bike, it looks like the front head pipe may need to be loosened and readjusted. Could be an illusion due to angle, but I'd try it to see if it gives you enough clearance.
Yeah, something in that pic above looks like it's off a bit. To me the rear pipe looks like its angled down ever so slightly which would cause the muffler portion to contact the front pipes muffler.
The following 2 users liked this post by Bubba Zanetti:
mmmatt (10-25-2024), Tailbreaker (10-25-2024)
Old 10-25-2024 | 12:53 PM
mmmatt's Avatar
mmmatt
Ok. So because of the crossover pipe, I'm not going to get much. Can/should I loosen the clamp (35 & 36 in the diagram) at the pipe and spread it out a bit? I can probably still push that front muffler forward a tad. It is about a 1/4-3/8 from the shield, but the shield is loose and I can maybe push that back a tad too to keep it from contacting the muffler.
Old 10-25-2024 | 02:52 PM
Tailbreaker
My suggestion is to loosen all connection points, adjust it where you need it and tighten back down.
Old 10-25-2024 | 05:07 PM
mmmatt's Avatar
mmmatt
OK. I'm going to give that a shot I just test fit the mufflers to the support bracket laying on a piece of cardboard, and it seems like they wont rub against each other, but the back of the front muffler is defiantly going to touch the bracket at the tip I have about 1/4" left to pull that nut all the way down and it is already touching the bracket, so it will be jammed tight to it. Is this going to be a rattle point? I guess I wont know until I try it! hopefully if it doesn't work, Dennis Kirk won't mind a little rub on the back of the front pipe when I return. Their tech is emailing with me and told me to go for it, so I should be covered.
Thanks again guys!
Matt
Old 10-25-2024 | 07:46 PM
mmmatt's Avatar
mmmatt
Cobra slip ons
The following 2 users liked this post by mmmatt:
Tailbreaker (10-25-2024), Yankee Dog (10-25-2024)
Old 10-25-2024 | 08:37 PM
Yankee Dog's Avatar
Yankee Dog
Could also cut the crossover pipe off flush and weld up the holes. Seen that one before, but it looks pretty good! I like the look. How much of a gap do you have?
If things are properly mounted, there should not be much movement to the mufflers. Especially if you go with that more rigid mounting bracket.
mmmatt (Yesterday)
Old 10-25-2024 | 09:08 PM
Tailbreaker
Cobra slip ons
Glad you got it sorted out. They look good.
mmmatt (Yesterday)
Old 10-25-2024 | 09:53 PM
mmmatt's Avatar
mmmatt
You are right about that crappy bent wire bracket. I ended up flipping the support on top of it to push the pipes up a bit and it worked out. I have about 3/8 between pipes.
Quick Reply: New to me 94 Wide Glide
