'98 Ultra Classic Front For Air Ride help!
Question. On my '98 Ultra Classic FLHTCUI, the front fork air fitting broke. How do you replace these and what type of fitting would this be called? Compression fitting?Is the part the fitting is attached to one piece and you don't replace the fitting? Recently had my front forks rebuilt and when I got the bike back no air to the front fork and small amounts of fork oil leaked out on the ride home.
Any help is much appreciated.
IDK if it was the shops fault or not but after I got it back from the fork rebuild front forks would hold no air and the red fitting broke that the line goes into. With the line not being connected I am getting some fork oil spitting out by the broke fitting.
The line was off the fitting and I tried to get it to pop up and it snapped so I cant get the line back in.
Perhaps you are looking for (42475-97B -MANIFOLD ASSEMBLY front fork air control)
It looks like an $80 US dollar part for the assembly.
Perhaps one of the used parts shops on e bay may have one.
A parts finder like the one below helps when trying to identify parts and part numbers.
https://partsfinder.onlinemicrofiche....asp?make=hdmc
trigger1911
08-17-2011 09:35 AM
