4th gear noise
4th gear noise
1992 FLHS, over the last 500 miles (guestamite) I've developed a noise when in 4th gear. Just turned 53k on the odometer. The noise sounds like the rubbing noise when you put two pieces of cardboard flat against each other and spin them in different directions. You could also say it sounds like when your driving 65+/- in a car and open the window a half inch. Only happens in 4th.
Makes me think something inside the tranny is rubbing and shouldn't be. Any ideas? Hopefully I won't need to rebuild the transmission.
deadbug
04-20-2008 09:08 AM
