I've done the LED swap on my '92 and turn signals need the load equalizer. The horn I believe is a different issue, probably a bad ground or broken wire. could be at the horn or the button. Did you check continuity at the button (when pressed)?
I got 12v at the horn. I did get the horn to lightly chirp for a split second. Ill check into it once everything else is is squared away.
My load balancer shipped June 29, yet doesn't even show being picked up by post office yet....
Can someone link me up with the correct puller needed to remove the clutch assembly? My primary has began to drip,will be replacing the inner and outer primary gaskets and do fluid changes.
