Spark Plugs
Spark Plugs
Doing one of the major servicings on my 98 FXSTC and decided to try a different set of plugs. After a fair bit of research, I settled on NGK Iridium spark plugs to replace the base version NGK plugs. Boy-oh-boy what a difference a set of plugs makes. She starts easier, idles nicer and pulls harder than a you-know-what! If your plugs are due for a change, then I would suggest doing some research and opting for a more performance-oriented plug. Like I said, the NGK Iridium plugs worked a treat for me and it was the best "bang for buck" for me so far. Highly recommended although no doubt other manufacterers sell a similar product. There are plenty of sites on the web that can give you the cross-reference so you get the correct plug for your bike.
RE: Spark Plugs
I replaced my plugs with Screaming Eagle plugs, and I too noticed an immediate improvement.Esp on starts and I actually gained an extra couple of mpg. if I hadn't experienced it myself, I would never have believed it.
Probably the cheapest, and most noticeable performance mod Ive done in the last 10 years!
RE: Spark Plugs
ORIGINAL: mustasz
I have to check it out,maybe my Champions are not as good as I thought,M
My Evo has over111k miles on it, the Champions are one of the things I never even think about anymore.
RE: Spark Plugs
I have used Screamin Eagles, NGKs as well as others, but still like the Champ RN12YC. As far as noticing a difference. Just putting in new ones makes a difference no matter what brand they are. Can't see the extra money for the screamin eagles. Champions are plentiful and reasonably priced so I will stick to them.
RE: Spark Plugs
ORIGINAL: G wood Todd
So whats the part # on the NGK Iridium plugs. I'd like to try them out. Thanks
I am contemplating trying them out after reading this thread. I tried the splitfire plugs and noticed a great improvement until I fouled them out. Then I went with the ones I had lying on the shelf in the garage.
RE: Spark Plugs
When my rings were bad the Screaming Eagle made a big, temporary improvement; but once the top end was done I just ran the cheap Autolite 4265 plugs the indy shop recommended. They are cheap and Advance Auto has them hanging 2 in a pack, out where I can easily grab a pair whenever I am in for wax or cleaners.
