What does 108,000 miles look like on the inside!
Old 11-20-2023 | 10:17 AM
downzero's Avatar
downzero
Originally Posted by sbrmike
I would rethink the forged pistons. Forged pistons are more for racing where there is no "Break In" before running. I have always liked / used cast pistons on the street. See what others think?
ETA: I don't think the internals look too bad, especially considering that mileage.
Forged pistons are noisy and have to be fit looser. I would never build an engine with forged pistons unless it was for boost or nitrous.
If this bike was mine, I'd hone the cylinders and probably put two fresh pistons in with my choice of compression ratio and put it back together.
Old 11-20-2023 | 10:33 AM
TwiZted Biker's Avatar
TwiZted Biker
At a 100k I'd check the rod play close and the wrist pin bushings at the minimum, indicator on the end of the pinion to check run out, but from the looks of those pistons crank may be in spec still. They are tight I'd do gaskets and seals and leave the lower alone.
Architect (11-20-2023)
Old 11-21-2023 | 02:37 PM
Rains2much's Avatar
Rains2much
Seen far more galled up expensive forged pistons than I have cast in low mile motors.
You know Similarly I have seen a lot more cast pistons in my rear view mirror.
Old 11-21-2023 | 03:13 PM
98hotrodfatboy's Avatar
98hotrodfatboy
No one answered my question... Legitimately, when did the MOCO start using coated postings?? Anyone?
jake24lt
Touring Parts
12-16-2022 02:12 PM
AftaDynaMint
Stock Harley Take Offs
11-24-2021 02:01 PM
johnwesley
05-04-2021 07:33 AM
texashillcountry
Evo Era Parts
01-07-2018 02:16 AM
sick_dyna
03-01-2009 09:46 PM
Quick Reply: What does 108,000 miles look like on the inside!
