What does 108,000 miles look like on the inside!
I can’t raise the compression without going to forged pistons, but maybe that’s a mistake !?
I honestly don’t really know what I should do,
on the one hand I , like most folks, would enjoy more power. I also value the smoothness and quietness of the stock EVO w/ the EV13 cam I’ve ridden for 27 years.
Yes, no, maybe on the compression thing with cast pistons.
Hence would check piston rod top bronze bushings to wrist pins, if the rod bushings need to be replaced if too much slop, lathe the factory gaskets off the base of the jugs to start with since only take a few mins that way, get the jugs bored next size up, pick up the new pistons, rings. gasket set, then dry fit the jugs to base with new gasket, new pistons in place with just jugs bolted down tight, and see what squish you have from top of piston all the way up, to top of jug, then add in the thickness of the head gasket in play.
Ideal will be .030", and if you have a larger number than this, than can face the bottom of the jugs back in the lathe to get the .030" squish. I would not go less than this if the plan is to run on stock pump gas, since higher compression could be need to run higher that what you can find for octane pump gas, plus the whole starter problem with high compression and no compression releases on the cylinder as well.
Note, if your plan was to go high compression, then really need to change out the piston rods to forges as well.
As for heads, break them down and take a good look at the seats and valve faces for rust pitting. Sometimes you can save the valves, while most of the time with valve and guide wear, new guides from the old one worn too much, valves, springs, with the seats re-cut to remove any pitting problems on them. Hence the pitting problem is more of the amount of time bike sat no ridden, where moisture got to both surfaces to cause rust pitting over time itself.
Also, with top end off, good time to check the lifters, the cam lob surfaces for case hardening worn off the lobs, change out the cam bearing, and such as well.
The following 2 users liked this post by Dano523:
Mountainkowboy (11-21-2023),
Yankee Dog (11-19-2023)
I had a friend of mine that had a 94 road King and he bumped up the compression a little bit and put in a V-Sunder EVL 3010 cam and I got to tell you I was really impressed with that at 9.5:1. I know a couple guys had said stick with the cast but if you're going to do it might as well go with the forge pistons that's just my opinion.. I know that's exactly what I would do that's all..
GOGOBECK (11-20-2023)
The following 5 users liked this post by Architect:
98hotrodfatboy (11-20-2023),
GOGOBECK (11-20-2023),
hvacgaspiping (11-20-2023),
t150vej (11-20-2023),
TwiZted Biker (11-20-2023)
I would rethink the forged pistons. Forged pistons are more for racing where there is no "Break In" before running. I have always liked / used cast pistons on the street. See what others think?
ETA: I don't think the internals look too bad, especially considering that mileage.
Seen far more galled up expensive forged pistons than I have cast in low mile motors.
